difference between lt30 and lt40
Started by Norwiscutter, October 25, 2005, 03:04:57 PM
Norwiscutter
Could someone please explain to me the difference between the lt30 and lt40 woodmizer mills.  I have researched the forum a little, as well as the woodmizer site, and found little to distinguish the two.  Much thanks in advance!
Si vis pacem, para bellum.
stumpy
I just bought a used LT30 and I'm told that the only difference is the length. There also may be some different power options. If I'm wrong, I'll see in any responses you get.
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Norwiscutter
Never mind guys. Finally figured it out. ;D
stumpy
ronwood
Stumpy,
You are correct it is only the length of the log that you can cut.
Ron
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
