need info on 240 International
Started by emm, December 15, 2005, 01:49:42 PM
emm
I need to know where to put the hydralic oil in a 240 internationl gas tractor, and also how to tell when its full.
thanks for your time.
Corley5
I've got a 240 Farmall and as I remember you put add hydraulic oil on the left side under the gas tank.  There should be a pipe plug there that sticks up at an angle.  That's how the Farmall is and it shouldn't be much different than the International.  Yours has the pump that runs off the timing gears?
emm
I'm unsure where the hydraulic pump is but I think its either on top of the transmission or at the front of the tractor
Corley5
emm
 8) Thank you the pic is great..... Now i can fill it up and my hydraulics will work THANK YOU ! ;D
Corley5
Fla._Deadheader
Ain't this place GREAT  8) 8) 8) 8) 8)
