$20 and runs like a champ ....
Started by TexasTimbers, April 06, 2006, 09:10:25 AM
TexasTimbers
IL Bull
That ought to blow some sawdust around.   8)
Case Skid Steer,  Ford Backhoe,  Allis WD45 and Burg Manual Sawmill
Coon
When I first looked at the pics it almost looked like some kind of jet pack that you strap on your back and go flying around.  :o :o :D.
TexasTimbers
If I fill the tank with AvGas maybe  it can   :o  ;D
Corley5
It makes my back ache just looking at it  :)
junkyard
Ah! a Solo Blower. Neighbor had one he "painted" Scotch Pine Christmas trees With it. Some green, gold and silver. This was in the 70's.
                      Junkyard
If it's free, It's for me. If for pay, leave it lay.
Ah Yes!   That's one of those machines that you use to blow your dirt and leaves into the street and onto your neighbor's yard.  ;D
Den Socling
cripes!  :o I first thought it was an old VW engine.  :D
sawguy21
 :D :D :D Tag three more on and it would be.
maple flats
That would mean 4 x $20 or $80 is the price for a VW engine, sounds about right if it is new! ;D
TexasTimbers
Hey it is heavy. It might find it's way on ebay.
Not only that, I found out why it was 20 bucks. It runs for about 10 minutes then quits. Thing is, it starts right back up - no waiting period - runs 10 minutes and quits. Any ideas? Other than ebay?
sawguy21
Pull the muffler and check for piston/cylinder wall damage. I would also put an inline neon spark tester between the plug and the lead. See if the spark is still healthy as it quits. Sounds like the ignition module is failing when it gets hot.
