Sawdust - What to do with it?
Started by 50 Acre Jim, June 02, 2017, 08:18:59 AM
4x4American
I just pile it outside and sell it loaded on your truck for $10/cubic yard.  Mixed hardwood.  I mainly saw northern hardwoods and the ones I try to put in a different pile are cherry walnut and butternut.  My neighbor comes with his loader and brings it to his dairy farm for putting down in the aisles for more traction and to line the barn cleaner and if hes desperate he uses it for bedding.  I also have a few horse ppl and a pig farmer that come and get it.  I tell them its not good for bedding but after that I can't control what they do with it and if they don't buy it from me they buy it from another sawmill so I might as well sell it.
Boy, back in my day..
Dewey
Quote from: Brad_bb on June 02, 2017, 08:52:22 AM
Remember you cannot use certain woods for animal bedding.   Plus very fine sawdust is more likely to be inhaled, which is not good.   For me, I mill about 6 hours a day.  I have a manual mill which is not as fast as say a LT40 super hydraulic.  I burn all of my saw dust in 2 well ventilated burn barrels.  Once you get some coals going, you can pour the dust in so it's at a slant in the barrel, leaving one side with some exposed coals.  The heat will dry and then burn the dust.  Start the barrels as soon about an hour into milling.  If you have a bunch of bark, it's usually drier and will burn well to make coals.  As you get dust put your first batch in and a few hours later check it and if it's nearly burned down, then add another batch, then a few hours later repeat.  I usually have the last batch in by evening and by morning, there's nothing but ash.  Don't do it in high wind conditions or at high fire hazard times.  Keep an eye on it and have a plan in case of fire spread.  My tail-er wasn't watching well enough one time and the surrounding grass caught on fire.  Luckily it was mowed short grass so he did get it out, but i gave him a hard time about "burning my farm down" for awhile-teasing.
We are able to keep up with the bark and dust we produce using two vortex burn barrels.  When
burning bark or wood, these barrels burn pretty clean(no smoke), but dumping dust in will initially create smoke.  https://youtu.be/-0J0zRiDAmE
Well  I get rid of it by the Dump Truck load...  Sawdust and shavings......  all used for animal bedding no casualties yet..... Plus $$$$ in my pocket...
Knute
Oak or pine sawdust works good for Kitty litter if you dry it.
nativewolf
Make the $.  There are worse things for a horse than sawdust, standing in wet dung for one.  Give a horse enough time and they'll be rolling in dust every hour in any case.  Also, most horses are given quite a bit of access to fields and dont spend all day in the stalls.
Liking Walnut
Peter Drouin
I trade mine for cow pooo. And give it away for free. On a Saturday they'll be a bunch with grain bags, cleaning it all up for me. 8)
A&P saw Mill LLC.
License NH softwood grader.
Cazzhrdwd
This is my twentieth year owning a sawmill, I've had cattle even longer. Its bar nun the best bedding I've ever used. It mixes with manure very well and makes excellent fertilizer with a bit of lime added to it.
96 Woodmizer LT40Super  Woodmizer 5 head moulder
killamplanes
I don't saw all day everyday. But alot of mine gets blown a far with the 40mph windy days we have around here. I bet if you looked hard enough you could find sawdust a half mile away. It drifts 30ft away from mill on windy days.
jd440 skidder, western star w/grapple,tk B-20 hyd, electric, stihl660,and 2X661. and other support Equipment, pallet manufacturing line
ellmoe
      I sell mine primarily to potting soils cos., the balance goes to horse bedding and for use in gardens. If the dust is placed on top of soil it will act as a mulch helping reduce weeds and retaining moisture. Eventually, it will break down, if you cut into soil at a later time it is necessary to add nitrogen, chicken manure works well. We are dealing with sandy soils here, so any organic material is a positive.
nativewolf
Great topic and some really innovative, simple answers.  So, maybe an interesting poll question.  How many people are selling sawdust and how many not.  Seems that a large % are selling.
Liking Walnut
red
I know I sound like a broken record but we have talked about this many times. I can remember a member named Getoverit from Florida . He loved sawmilling started with a bandsaw then also had a swingblade . He purchased a few trucks was doing great. Then hurt his back , no more sawmilling. He makes guitars last I heard. Please use the search feature.
goose63
I've had people tell mw thy want the sawdust for the chickens or the garden tell them bring a trailer or some thing to put it in will call you when it's full it's free so far no one has come to get it may be I should charge for the sawdust
goose
thank you to all the vets
tomsteve
Quote from: 50 Acre Jim on June 02, 2017, 08:18:59 AM
  Can it be used in the flower bed or maybe around landscaping?
the problem that occurs with using sawdust in flower beds is that will compact as it gets wet. that creates a wet matt where funguses and diseases start.
if you have a fence line with weeds, it works great to snuff out the weeds along it.
Crusarius
That was the entire reason for the post :)
redprospector
Here in the desert southwest, I haven't had to do anything with it yet. About the time I get enough to start thinking about it, a wind storm blows through and redistributes it. Depending on the direction of the wind, it either goes onto the vacant 8 acres North of me, the alfalfa field East of me, or the mobile home park South of me. We get a lot of dust devils too. When they come across just right, they turn to "sawdust" devils.
Brucer
I give all my sawdust away.
  • People put it in large bags and save it for the winter -- great for traction in icy conditions.
  • The metal fab shop across the street spreads it on the shop floor before sweeping up stainless steel dust and grindings -- it draws in moisture that keeps the toxic dust under control.
  • The gas station down the road keeps several barrels on hand for soaking up fuel spills.
  • Local farmers mix it with soil and leave it for a year or so to break down.
  • Local farmers spread it directly on paths, etc. to control weeds.
  • Any that's still around gets spread in the grass field next to my (former) milling site. Great soil there after 8 years.
One point for the farming and gardening folk ... the organisms that break down wood waste will draw nitrogen out of the soil while they are doing their job. Fresh sawdust depletes the nitrogen and kills plants. However, after the wood is decomposed, the organisms die off and return the nitrogen to the soil. Old decomposed sawdust helps plants grow. So ... plan accordingly ;D.
Bruce    LT40HDG28 bandsaw
