Server taking a beating
Started by Jeff, December 14, 2006, 11:36:37 PM
There are several things going on that are causing the server to be latent.  I'm going to being some occasional reboots to keep it running optimum in between. That means you may get some down times of 2 or 4 minutes at a time.  If you see the server running slow, or returning searches for the contest slow, give it a break and try a bit later.
Server going down for reboot in less then two minutes...
Dana
I tried to work on the Christmas contest last. The search area wouldnt come up. I figured too many hits were keeping it from displaying.
