13degree .055 meets log clamp
Started by MikeH, March 10, 2007, 04:24:55 PM
MikeH
 Got a little to exicted cutting last boards to fill kiln.
   I might have been mad but I knew I could post a picture for all to see. :-\
farmerdoug
MikeH,
That is one heck of a cut.  :o I hope it was not a new blade. ::)  You must have been cutting full bore.
Farmerdoug
Doug
Truck Farmer/Greenhouse grower
2001 LT40HDD42 Super with Command Control and AccuSet, 42 hp Kubota diesel
Fargo, MI
Bibbyman
You should try a little further down. The rod that the top-knot is mounted on is REAL hard!  ::)
Sawing since '94
MikeH
Quote from: Bibbyman on March 11, 2007, 08:06:52 PM
No Thanks, that might wreck the double hard blade.   ;D
LT40HDD51
Nice Bibbyman  :D
I once left the side supports up a little on my last cut. It was a small log with a 13° blade so I was moving right along, and it cut the head right off of the bolt that holds the rollers on the side support  ;D. Ruined that one...
The name's Ian. Been a sawyer for 6 years professionally, Dad bought his first mill in '84, I was 2 years old :). Factory trained service tech. as well... Happy to help any way I can...
