Problem with actuator handle on LT15
Started by Qweaver, May 04, 2007, 09:06:01 AM
Qweaver
The up/down crank handle is hitting the engine in/out handle when the engine is dis-engaged.  I can't find anything in the manual that addresses this. I have tried adjusting the turn buckle and changed the hole location to no avail.  I'm thinking of welding an adjustable stop on, but you'd think that WM would have alrady done that if it was necessary.  What am I missing.  There is no adjustment of the handle to crank angle as they are roll pinned on and the belt length is not an issue because this only happens when the belt is dis-engaged.  I'm stumped. ???
Quinton
sparks
Give me a shout here at Wood-Mizer and let's see what we can do. 1-800-525-8100 ext 1620. If I'm on the phone leave me a message where I can call you back.  Thanks
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Qweaver
Sparks is the MAN.  One phone call and all is well.  It was so simple that I should have seen it...but I didn't .  Thanks Sparks!  8)
Quinton
pigman
When is the new LT 70 going to be delivered. ;D
Yeah, I second Jeff.  What was the solution ???  I have not had that problem, but I want to learn from other's experiences.
Qweaver
Solution: The adjuster is a bolt on the brake lever.  As the brakes wear the adjusting screw is turned out to take up this wear.  My Duh.
Quinton
Thanks Qweaver.  I'm gonna remember that one and also remember to call Sparks if I run into a problem ;D.  How is the cabin progressing?
Qweaver
No actual progress on the house yet.  We have finished clearing land and planting pine trees and are now sawing the last of the lumber to finish the exterior of the house.
Quinton
