whatzit for a hat. (Solved: Boom for sprayer)
Started by Jeff, June 05, 2007, 06:05:19 PM
We aint give a hat away in awhile, so here is potentially an easy way to win one.  I'm making something today. Here is a picture of the materials. What am I building? First answer I deem correct wins a hat. :)
A new spray boom for the front of the ATV
Sprayer boom (for the rear, just because I was so slow from Tom  ;D)
scgargoyle
Spray boom for the side of the ATV :D :D :D
I hope my ship comes in before the dock rots!
woodhick
outdoor shower or fountain.
Probably a shower for the pig roast attendees.  :D
Woodmizer LT40 Super 42hp Kubota, and more heavy iron woodworking equipment than I have room for.
Burlkraft
Home made enema kit...... ;D ;D ;D
You should eat more fiber..... :D :D :D
Why not just 1 pain free day?
Dave Shepard
A destillery. Oh well, I don't wear hats anyways. ;D
Dave
We have a right answer.  Tom was sorta right but when he added for the front, that made him wrong. Beenthere wins a spare hat. Ya want me ta ship it or ya wanna pick it up? ;D
The boom I used before was really not the best. The neighbor let me use it, and it worked, but it was not a very good meter for the product. The nozzles were way to close and there were way to many. I am sure I was dispensing way more product then necessary due to repeated coverage of the spray. The thing was cumbersome as well. It was nearly 8 foot wide and could not be narrowed. You had to take it off to get down a trail. I'm making this one so it will stow in an up position for travel and have valving to be able to spray one side or the other or both. It will have 4 spray nozzles and will still spray 8 feet wide with a total boom width of around 6 foot.
Dave Shepard
Doesn't Tom already get a hat for his annual FF salary? ;D
Dave
No, I even have better than that!   I have a FF hat antique kit.  The older it gets, the better it gets.  Those new ones just devalue it.  ;D
Don K
Keep the pics coming, I need one for the tractor.
Lucky to own a WM LT40HDD35, blessed to have a wife that encouraged me to buy it.     Now that\'s true love!
Massey Ferguson 1547 FWD with FEL  06 GMC Sierra 2500HD 4X4 Dozer Retriever Husky 359 20\" Bar  Man, life is getting good!
I will. I'll document it and give a parts list and cost breakdown.  :)    I'm making my brother in law pay half so its only costing me about 25 bucks.  ;D
ely
jeff if you have some parts left over make a beer bong for the pig roast.
Our pig roasts arent those kind of affairs. :)  They are family events.
I'll have to make one for my wedding anniversary. ;D
DWM II
I'm kinda late gettin in on this, but I've got a empty keg I was gonna make a boom sprayer out of so I am VERY intersested in the parts list. :P
Stewardship Counts!
I'm only making the boom here. We already had a 16 gallon poly tank sprayer with a 12 volt pump. It came with a wand sprayer.
Don_Papenburg
Just a little advice .  Make that a dry boom if you make a wet boom with pvc some chemicals react with it and loosen the joints .  Just a little more hose and you will be set.
It is a dry boom. Thats why there is a roll of clear tubing in the pats pile. ;)   The PVC is only a light weight carrior for the nozzles hoses and valving.
I'm still missing some needed parts to assemble. Not sure what to use yet for lock rings to hold the nozzles to the clamps.
Don_Papenburg
Get the nozzle holders with the diaphram  so that they do not drip when you shut off the pump .  They have a quarter turn cap that makes cleaning the screens and nozzles a snap.
The first photo shows the pvc parts of the sprayer boom that are cemented together. the center length is 9 inches. Two pieces of 2" long 3/4 in pvc hook the two sets of tees together.  The tees that are placed together are 90° from each other. The pictures exlain it better then I can. :)
Parts that make up each nozzle.
Assembled nozzle mounted to one of the boom arms
Assembled spray boom in the "stow" position
Closer look at valving
Sprayer with just the left boom down with left valve turned on
Sprayer with both arms extended and both valves in the on position.
Here is the list of parts we used to make our spray boom, where we got them, and what they cost. I am sure you could probably put one together cheaper with odds and ends. Or you could spend a whole lot more if you used brass fittings and brass nozzles and tips.
The brass ball valves we used were the most expensive parts. You could eliminate them completely if you wanted. I wantd them so we could use one side of the sprayer or the other or both.
The sprayer mount is simplistic. You simply set the sprayer on top of the 20 inch "legs" I guess I'll call them and tie down your sprayer as normal.  The sprayer wont go anywhere, but if you happen to hit a tree or sign or something with the boom, the sprayer will just twist out the back with out destroying it.
Tractor Supply:
Plastic fittings:
3/8"  pipe x 3/8" barb double $.81 each                (2)   $1.62
3/8"  pipe x 3/8" barb single $.81 each                (2)   $1.62
3/8" spacing clamps               $2.46 each              (4)   $9.84
3/8" Ball valve                          $4.78 each              (2)   $9.56
3/8" T Nozzle thread barb       $2.58 each              (1)   $2.58
3/8" PVC clear 10 FT              $4.35 each              (1)   $4.35
Sprayer nozzle cap                  $3.98 Pkg of 4        (1)   $3.98
Strainer Poly Pro                      $6.00 Pkg of 4        (1)  $6.00
Tip Tee Jet 80 Flat                   $7.29 Pkg of 4        (1)  $7.29
11/16 Elbow Nozzle                  $2.58 each              (1)  $2.58
Walmart:
3/8s Hose Clamps                     $1.98 Pkg         (2)  $3.92
we bought the clamps at walmart because you could get a package 8 for 1.98. At TS or HD they were 89 cents a peice!
Home Depot:
3/4" PVC Tee Fittings            $.28 Each         (4)  $1.12
3/4" PVC Cap                       $.35 Each         (4)  $1.40
3/4" X 10' PVC                     $1.55 Each        (1)  $1.55
Zip ties                                 $1.57 Pkg       (1)  $1.57
Sub-total    $59.55
Michigan Sale Tax   $3.57
Total              $63.12
Now I just have to get back up North to test it!  :)
