Mobile Dimension blade runout & VA. hammering
Started by LKasdorf, May 30, 2003, 08:57:24 AM
LKasdorf
What is the maximum allowable rounout on the big blade on a Mobile Dimension mill? I called the factory and they say 1/10". I measured mine at about 1/16". Yet when I reported this figure, I was told that I should have it hammered anyway.
So, in paractical terms, at what amount of runout do you MD owners get your blade straightened out?
By the way, I measured the runout with the aid of the rubber-tipped outside guide rod. I adjusted it until it just touched the blade at one point. Then rotated the blade around to the largest gap, which turned out to be around 1/16".
ALSO- does anybody know of a good place to get a blade like this hammered straight in the Northern Virginia area? I'm in Leesburg.
dail_h
Stewart Saw Works New Road Gatesville N.C. 252 357 1850.Old company,been in buisness for years,do super excellent work. It's a little ways away from you but UPS will probably handle your blade
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
see_saw
when we put the mills together we use a runout gage mounted on the carriage. .020 or less is exceptable. whoever hammers the blade, no dish required, stiff&flat=good sawing.
