Burning poles to guard against rot and insects????
Started by Peterrum, May 01, 2008, 10:01:04 AM
moonhill
Where did the smiley face digging a hole come from. :).  They learned long ago that putting wood in the ground was a not so good idea.  Tim
Don P
So this would be a bad time to bring up pressure treated basements  ;D.
Peterrum
Thanks everyone for your input.  As it stands i don't see that anyone has any definitive proof that charring would work so I will probably forgo that thought unless something new is posted.  I think that i will try it on a couple of secondary posts though as a bit of an experiment.  Look for my thread in 5 yrs. time and I can give you an update.  I love the way these threads take off, like a drunken sailor, all over the place.  Very enjoyable reading though.........
moonhill
http://iceagetrail.umaine.edu/content/iceageinmaine/iceageinmaine.php
I had to try posting a link and thought this one would would work here.  It is way off topic.  Tim
It worked and it didn't hurt a bit, and very simple.
pappy
Very interesting link Moonhill  8) thanks
As far as post planted in the ground or even placed on top of a rock or a concrete pad I've seen folks use roof pitch like the utility company's do.. Not the most enviro friendly but it keeps the wood from rotting I guess..  ::)  At least it doesn't flow away like the fluid / oils from abandon / junk vehicles would...  I like the idea of the plastic sleeve, say use a contractor type of trash bag over the post end treated with roofing pitch...  :P
SwingOak
Maybe you could work out a deal with someone here who could send you some black locust.
