Propane
Started by Raider Bill, September 23, 2008, 05:27:56 PM
Raider Bill
Next trip I need to get my cook stove up and working. I have not purchased the dryer yet
I see those 100 lb tanks for sale and wondered what is the cheapest way to go.
1, buy my own tank  and either take them in to be refilled or have the truck come to me
2, have propane co supply and service tank.
Stove and dryer will be the only propane I need. Depending on operating price I could buy a elec dryer.
Will 5/8 copper work as supply line or does it need to be 3/4?
I've always herad that you should use flare fittings instead of compression is that true?
The First 72 years of childhood is always the hardest.
My advice on aging gracefully... ride fast bikes and date faster women, drink good tequila, practice your draw daily, be honest and fair in your dealings, but suffer not fools. Eat a hearty breakfast, and remember, ALL politicians are crooks.
Raider Bill
wonder what happened there with the lines? Doesn't come up in the preview
WH_Conley
We have a propane hot water heater and cook stove. Was cheaper to take tanks and have them filled until 2 daughters moved back home. If you don't use enough there is usually rent on the company tanks. (250-500 gal) Don'y know about them providing 100 lb tanks.
3/8  line should do the job, make your splices outside the home. Safer to have 2 clean lines running in then to have splices inside.
I have heard the same compression vs flare. No idea.
Bill
Quote from: Raider Bill on September 23, 2008, 05:27:56 PM
Take the bracketed 's' out in point number one... :)
Raider Bill
Well there you have it!
Don_Papenburg
You want 5/8 from the main reg on the tank  to the secondary at the house .
from there use black pipe .  I used SS in ground and through walls/Floors .  I polished the pipe that was exposed in the living area.
  Use flare fittings on copper .  If you need a splice inground , I solder the copper tube.
Raider Bill
depending on where I put the tank everything should be above ground.
Have 100" 5/8 copper I never used figure to save soem $$$ and use it.
Still wondering if having my own tank will save $$ or not be worth the hassle.
Haven't bought dryer yet. Looking at price of Propane maybe a elec dryer would be better for me.
Got to have a gas stove though.
Don_Papenburg
If you can get a tank cheep it is well worth the fredom to buy on the open market .  I bought old NH3 tanks aired them out and put in brass valves . NH3 uses steel valves .     Look at old farm sales or fertalizer companies for an old 300/500 gallon apllicator . Those have gone out of favor and should sell cheep.
Onthesauk
We wanted our tank buried, out of sight, so had to buy one, couldn't lease.  But as a result we can buy propane from anyone, not locked to a single supplier, although have ended up staying with the Co-op.
John Deere 3038E
Sukuki LT-F500
Don't attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Raider Bill
Do they or will propane companies fill on site privately owned tanks?
I'm going to put mine under the back deck.
What do you guys think, should I go with elec or propane dryer?
Norm
The ones around here will fill any tanks as long as they meet the safety codes.
As for the electric or propane dryer I would have told you propane a couple of years ago but with the uncertainty of propane costs I'd go with electric.
Most around here will only fill there own tanks.  Some will fill homeowner owned tanks, but he homeowner must pay for a tank inspection.
flip
Go with the electric dryer.
Timberking B-20, Hydraulics make me board quick
Raider Bill
Quote from: flip on September 25, 2008, 01:14:57 PM
I think I'm going to do that.
ADAMINMO
My wifes grandpa pays $35.00 per year for lease on his 300 gallon propane tank.Kinda cheap and worth it if you ask me. If anything goes wrong with it they fix it and is no problem to the person leasing it.
Raider Bill
Cheap for peace of mind I guess.
Sometimes I just think too much :o
Will check into it next trip.
Thanks!
Larry
Call all the propane dealers in your area.  In north Missouri a propane dealer wouldn't even consider a gas delivery for a 100 pound tank.  If you hauled it in (a hassle) for refill they would charge the same absurd price as gas for a 20 pound BBQ bottle.  I had a 500 gallon tank for the house that I owned, and a 250 gallon tank for the shop that I leased.  Lease was $30 a year and they maintained it along with painting it every few years if I asked.
We have a gas dryer. Wife wanted it for some reason.Dries clothes,it works good.
cheyenne
They may not let you put it under a deck & it must be 10' from any type of exhaust or heat source. Don't forget drip tubes on the appliances. 5/8 is fine use only flare fittings & use s/s flexable lines to appliances & leak test everything.....Cheyenne
Home of the white buffalo
scsmith42
Bill, re propane I prefer the larger, burried self-owned tanks.  It's nice to have a large supply on hand, and one less trip to make to town.
Re the dryer, gas works well, and if you have a small standby generator you have the added benefit of being able to run the dryer during a multi-day power outage (such as if an ice storm wipes out a lot of power infrastructure).
With an electric dryer, you'd need a pretty large generator (probably 12K or larger) in order to power it.
If in doubt, be sure to run both 30A wiring and a gas line while you're building so that you can choose between gas and electric in the future w/o having to rework your house.
That's also a nice feature of propane / wood heat - the furnace will work on a fairly small generator since all you're running is the blower fan motor.
Scott
Tom's 3638D Baker band mill
In my folks' experience, they pay more in rent for the tank than they use in propane. :D They are on heat pump, which is a lot cheaper. The propane company here doesn't do maintenance, it's up to the user to hire an independent and to keep it painted. To top it off it's a monopoly so the propane company can't loose.  ::)
Raider Bill
I'm convinced elec will be the way I go for the dryer. I did buy a 5 burner gas stove as I prefer to cook with gas and will proceed that way.
The deck is open on 3 sides, no exhaust, heat source nothin under it for 48 ft. Deck is 6' off the ground and will be a straight shot to run the copper all above ground.
Plus just having the stove propane cuts the size of the tank way down.
Rockn H
Just thought I would throw my two cents in. :)  Here it's state law that the tank must be located 10' away from any part of dwelling including porches and roofs.
Here one of our local suppliers charges the same (decent price) per gallon no matter what size tank, portable or stationary.  They all charge more per year for their lease tanks though,  if you don't use at least 100gal.  I think it's $30 vs. $45.  They will all fill a privately owned tank, but if it has less than 10% in it , again by state law, they have to do a pressure test on your system to check for leaks.  The test is in the $40 range.
I'd make questions out of what everyone here has said and then take Larry's advice and call all the suppliers in the area. :D
Good luck....that is, I hope you don't have my luck and have to do it twice to get it up to state code. :)
