I need some ideas...
Started by scsmith42, December 01, 2008, 10:17:53 PM
sharp edge
Wanted to add that it should be covered with fiberglass so fire can't spred as fast and keep the Ins. co. happy.
SE
The stroke of a pen is mighter than the stroke of a sword, but we like pictures.
91' escort powered A-14 belsaw, JD 350-c cat with jamer and dray, 12" powermatic planer
thedeeredude
Hmmm....I see a solution.  Order a bunch of tools and sawmilling toys and stuff, and use the packing peanuts for insulation.  and when the wife asks, all ya gotta say is, honey I need it for the free insulation they send. smiley_lit_bulb
Ran across this AgriMetal bedding chopper, that might work well for the insulation. They rent these locally around here, for chopping hay/straw bales for covering new grass seeding.
Might work well for ya.
This was on craigslist today.
http://madison.craigslist.org/grd/947071761.html
scsmith42
Thanks BT - something like that would probably be ideal.
Scott
Tom's 3638D Baker band mill
Left Coast Chris
Scott,
The thought path I was going down was trying to feed it through your planer then suck it up through the vacuume system. Place an extra section of hose on the discarge end of the blower and blow it into the walls.   The pieces would have to be big enough and uniform thickness to go through the planer.........
Maybe the leaf mulcher is the best idea then hook up your vaccume blower up to its discharge and blow it into the walls right from the mulcher.  Two guys.... handle it once.
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
scsmith42
Quote from: Left Coast Chris on December 06, 2008, 10:18:34 PM
Scott,
Chris, I think that you've got a good point here.
Re the planer, I think that I'll be better off with larger chunks of insulation, rather than the shavings.  My problem right now is that the chunks are so large, and so unusually shaped, that there will be too many air voids in the wall.
