New Circle Miller
Started by Tripp, June 15, 2009, 11:04:31 PM
Tripp
I want to say thanks to all the Forestry Forum members. I have been restoring a Foley Belsaw m-14 over the past few months. The information I have gained from from the site has been a great help. I have set the mill up on two 37 foot steel beams and is powered by a inline six Toyota Landcruiser engine. I tried to send pics but I believe the file sizes were too large.
Thanks again.
Tripp.
Sprucegum
Welcome aboard Tripp  8)  8)
Seems like those Foley-Belsaws are getting more popular.
Don't give up on the picture thing, it aint as hard as it seems at first.  :P
Welcome Tripp,what are you using for a governor on the engine??Good to see rebirth of so many old handset mills.Frank .c,
Tripp
I am using a universal Audiovox cruise control to govern the engine. I can lock it in at the rpm needed, depending on what gear combo I am using, and it will keep the saw speed very constant. It uses vacuum to apply throttle under load. Tripp
Good conformation Tripp, always heard a cruse control would do the trick never tried it myself.Frank C.
fishpharmer
How many bfg do you get?  Board Feet per Gallon.   May not be such a term.  I just know them old LC six's are kinda thirsty.    Bet it doesn't bog down much, they have alot of torque.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Meadows Miller
Gday
Welcome to the forum Tripp its a bloody great place  ;) ;D ;D 8) 8) I like the pics of you mill Verry nice settup you have there Mate ;) ;D 8) 8) Im looking forward to you imput on the forum you'll have a ball Mate  ;) ;D 8) 8)
Reguards Chris
4TH Generation Timbergetter
Puffergas
I had to resize my picture to 45KB or less in order to up load them into an album.
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, Trojan 114, Timberjack 225D, D&L SB1020 mill, Steiger Bearcat II
Tripp
I can usually run about half a day on 5 gallons. Right now I am running a holley 2 barrel carb that is pretty worn out. I hope to replace it soon with a rebuilt Asin or a weber. Should help fuel consumption and performance.
Ga. bow-man
Tripp
Hope you've got 5 gals for Tuesday AM, I will be there
at 6:30 AM.
GA bow-man
Tripp
I will be ready. Got a pile o logs ready thanks to your great tree felling techniques.
My AC is still out in the house so I will be warmed up and ready in the morning! (88 degrees inside at 9:40) Looking forward to the morning.
Tripp
