frick elevator fozen
Started by sawthemlogs, January 17, 2010, 06:36:50 PM
sawthemlogs
weather finally broke a liitle so i decided to saw,,,when got tractor hooked up to check things out..elevator(drag chain)was froze in the pit >:(.aterabout hourand half of chiseling andscoopin and a shear pin iwas ready to go..i am trying to get afew pics on here..took me longer to get pics here than it did me sawing all day :Dany comments will appreciated   ...thanks
R.D.
fishpharmer
STL, that's a nice looking outfit you got there. I love seeing closeups of circle mills running.  When I was a kid, my dad sent me to a circle mill kinda like yours to get some oak fence boards.  The mill was only a few miles from the house.
Well your mill brings back memories.
What kind of tractor you running there?  Also, what kind of log.  I have family in Lexington, would be cool to see the mill run.
Thanks for the pictures. 8) 8)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
sawthemlogs
the tractor is a farmall wd-9 i am about 45 miles from lexington down bg parkway...bardstown.. welcome to stop anytime. I was sawing pine tops from the last ice storm.i still gotta a lot 16 footers  24 to 30 dbh to do
R.D.
woodbe
You have a nice set up there. I really like the tire drive that is a good idea. It is always nice to see others pictures. Thanks
Woodbe
Appreciate the pics, and the time you took to get them posted. 'spect it will be easier next time.  8)
Cool power transfer.
Carpenter
Nice set up.  Ingenious power transfer.  Simple and effective, you reversed the direction of the PTO to run the right handed mill and basically made a slip clutch at the same time.  And if you wanted to run the mill at a different rpm than 540 you could use a different sized tire.  I like it.  Thanks for the pictures.
Coalsmoke
Great looking mill. You've taken excellent care of it by the looks of it. I like the tire idea.
Visit Coalsmoke's website at www.coalsmoke.com
2008 Norwood Lumber Mate 2000 with Honda 20HP engine.
White 2-60 Field Boss > 65HP Tractor with loader.
Husky Chainsaws 353 and 395XPG heavily modified.
Loving wife who endorses all of the above :)
captain_crunch
Nice set up those belts for carrage travel alwaws fasinated me the way they were engineered mine has been replaced with a hyd motor
RD,very nice setup,does it take alot of pressure to hold the tire to the pulley and is slippage a problem.??That Heacock drive is a clever lashup ,he must have been a clever dude,I've got a friction feed.Something you never see mentioned but is very important is how the feed acts as a brake when you gigback.You have a heavy carriage and a one ton log giging back at a good clip, like a runaway freight ,you can't just let it slam into the stop everytime.The Heacock and the friction feed give you good variable control to slow and stop the carriage.I'am not sure how hydraulic feeds handle it but you don't want to stop suddenly.RD,also a good idea to have your bridge over the shaft especially if you cut alone.Frank C.
sawthemlogs
Quote from: bandmiller2 on January 18, 2010, 07:00:03 AM
hello frank..i have the tire pressure 25 psi..when i tighten i pull tire in till it just touches then pull it in maybe half  in. more. i prefer for to slip first...it rarely does unless i throw one of them36 dbh white oaks on....then it may squel a little...you mentioned a runaway carriage mine did that once,,,luckily did get it slowed but it still snapped off the stop..thats one thing about them flat belts sometimes they will get shorter if not used in awhile and they tighten up..now i make a point to run carrige back and forth at low idle speed to see how it reacts before i put on a log...another learning curve i guess...thanks for all comments and advise
R.D.
KyTreeFarmer
Hey nice setup. Enjoyed your pics. When I think sawmill, old circular mills are the first thing that comes to mind. I need to scoot over for a visit soon. I live near Lexington.
KTF
Woodmizer LT15G
Belsaw from Sears & Roebucks
8N Ford
87 Kubota 2550 W/FEL
Ron R.
R.D. Nice looking set-up. Need to saw some logs myself but too onery to get out and get'r done. I'm not too far from you. South of Hodgenville. Maybe weather holds a few more days I'll get some sawing done myself. Really enjoyed the pics.   Ron
Slingshot
  Guess I'd may as well join the party (or sawin'). I'm not far away myself, just north of Hodgenville, about
halfway to E-town off Hwy 210.
   sawthemlogs, I like the looks of your mill, almost bought a new Bellsaw back several years
ago when they were still being sold new. Even bought a couple cant hooks, (which I am using now) but never bought the mill. Little more than I swing back then. Had my band mill now a little over a year.
  Ron R, been wanting to check out your Bellsaw; maybe this spring?
________________________-
Charles
             sling_shot
sawthemlogs
HELLO RON and SLINGSHOT   I now the area...i knew some folks in buffalo and mt sherman...we go to the orchard on210 to get apples..maybe better weather will make a run in your neck of the woods,...
R.D.
Dave Shepard
Thanks for sharing the pictures. I sure would like to hear that WD-9 purring away on that mill. :)
Coon
On the old mill we used to saw on we had the same kind of setup with the tire.  Slippage was often a prblem with our setup until we changed the camber of the tire.  Once we had this figured out we thought we had it made in the shade until the first oversized spruce log made er slip.  I was tailing at the time so I grabbed a can of belt dressing and gave the flat pully a good dose.  That was the last time I ever heard it slip....
Ron R.
Charles and R.D., you're more than welcome to drop in any time. Might even scrounge ya up a cup of coffee and a slice of pie.........Ron
KyTreeFarmer
Quote from: Ron R. on January 19, 2010, 10:55:22 PM
Ron
If I had known you had pie.....I would have already been there!!
KTF
Woodmizer LT15G
8N Ford
