540B blade chatter
Started by Caseystree, September 25, 2022, 07:54:10 AM
Caseystree
After it's been sitting a while blade chatters bad almost air bound until you use it for a while it gets better
BurkettvilleBob
I think that's pretty normal on old stuff. I assume it's losing pressure or the fluid is draining back while it's  sitting? Nobody wants to buy that thing eh? I talked to you about it awhile ago, I'd just looked at Justin's.
C5C Tree Farmer
It sounds like the transmission oil pump is getting weak. This pump provides oil to the crankshaft driven hydraulic pump mounted on the front side of the motor.
