It's cold down here!
Started by Tom, December 17, 2003, 01:11:15 PM
Gus
cktate,
Fastest way to put up hay is loose. You can put it up a tad bit green and it cures in the stack. Best feed I've ever seen. Still green when you feed it. Put a little loose salt on between loads and you can put it up even greener and the critters will trample each other trying to eat it.
Gus
"How do I know what I think unless I have seen what I say?"
chet
Harold, we switch everything over to ATF in the winter and use tank heaters in the hydro tanks. It's da only way to go when it gets below zero.
