new mill
Started by argyle1, July 10, 2011, 06:19:42 PM
argyle1
maybe this will work---even tho I'm not sure what I did
argyle1
ok that worked---I used this old holiday trailer for the axles and hitch---saved about $2000 there
argyle1
I'm on a roll now (maybe)--just need to figger how to put text with pics so i can explain what I'm doing    ---think i found a way---#1 is how wheels are mounted--#2 is saw frame base---#3 wheel---#4 carraige guide system---#5 up and down carraige guides---#6 lift shafts and sprockets installed---#7 long cylinder for setworks---motor for up and down didn't work well so changed it for a cylinder as well---#8carraige drive mtr---#9 ready to roll---#10 first log---#11 dog set up---i since added another cyl to line up front dogs  (to line up log)
customdave
Hey Argyle, lookin good, looks like your havin fun . Play safe!
                                              Dave
Love the smell of sawdust
I can't tell if you have them, but you probably will need some wipers to prevent sawdust buildup between the rails and rollers. It looks like I see some buildup in the 10th picture.
Meadows Miller
Gday
Argyle Thats a nice mill you have built yourself there it runs well now and I reckon it will be running even better in afew months time when you get it tuned in and finished Mate  ;) ;D ;D ;D 8) 8)
I also love the Patrick Loader too they are a bloody good machine  ;) ;D
Regards Chris
4TH Generation Timbergetter
argyle1
hi Magicman---the sawdust you see is on the bottom side of the 3/8 x 3" angle iron I used for a guide bar--the rails are actually under the chains, but I plan to change that setup as I think the chains will wear the rails--the wheels have teflon wipers in front of each
hi Chris
I've had that old patty since 1977---my wife prefers it to the brand new  624 JD we had--2 engines and 1 tranny in 34 years--it doesn't owe us, tht's for sure
