Becoming more Visible
Started by Magicman, February 27, 2012, 01:54:00 PM
rmack
just checked my '09 tractor, haven't seen it much the last 4 months ::), amber and red on the flashers/signals on the back side, amber only on the front side.
i have an 18' foot trailer that has the lights on the fender sides, the light fixture is split into amber on front, red on back... no amber on the back end of the trailer.
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
customsawyer
Red oaks I would recommend driving not running. ;D
www.thecustomsawyer.com
red oaks lumber
you havent seen my driving skills yet have you? running might be better :D
Quote from: Chuck White on February 28, 2012, 06:39:08 PM
Lots of new vehicles now have RED tail lights, RED brake lights and AMBER turn signals.
I'm not sure if the same would hold true for trailer type vehicles.
That's the norm for pretty much all the world apart from the US. You can always tell a US import car here by the Red turn signals at the back. European, Japanese and Australian all have orange turn / hazard lights front and back.
Otherwise Red at the back, White at the front.
Quote from: rmack on February 28, 2012, 03:08:23 PM
not trying to be disrespectful
Not at all.  I researched as best as I could and I can assure you that it is crazy.  The guy at the truck store that sells the flashers to loggers to attach to extended logs, sells Amber to Mississippi haulers and Red to Louisiana haulers ??  Then a Mississippi logger on the Forestry and Logging board said that he is using Red.  ??
The turn lights and flashers on my truck are Amber and the brake lights and turn lights on the sawmill are Red.
This flasher that I bought blinks much faster than my turn signals and I'm thinking that the Amber color will be seen simply as an alert and not confused with my turn signals.
I hope that none of the above made any sense to anyone, because if it did, then I surely am whacky.  smiley_dizzy
My objective is to minimize the depth perception "problem" with that small part of the sawmill extending rearward which is why I have used that triangle on the rear outrigger.   I saw my first long log flasher a few weeks ago and asked a question in the Forestry and Logging Board.  LINK
Quote from: John S on February 28, 2012, 01:21:51 PM
Any problems with the magnets holding on during transport?
I really do not think that it would vibrate loose, but I handled that possibility today.  The flasher now has it's own lanyard.  Actually it is my WM 25th Anniversary lanyard.  Anyway, I can just loop it over the rear stabilizer and if the flasher does jar loose, it will not be lost.  It now has it's own safety belt.   ;D
trapper
I saw one like that at our local fleet farm for around $15.
Had 2 magnets on it.
I was never comfortable with the magnets that were on the flasher.  Those that are design for a log end has a plate attached, so I just modified mine so that it now has a plate.
I removed the "earth magnets" and screwed the plate to the back of the flasher.  I drilled a hole for my pin.
The pin goes through the attached plate and the rear outrigger and the on/off switch is still accessible.  It is easily detachable before setup.  The flash rate is very fast and will not be confused with a turn signal.
DR Buck
Quote from: backwoods sawyer on February 27, 2012, 11:59:37 PM
Half the problem is the salmon color fades away into the background, changing to Contrasting colors also has help with visibility along with 10' of refletive tape for side and rear visability ;D
That sure looks like a John Deere Green Wood-Mizer.  ;) Florida Dead Header had a homemade (Homey) mill  that looked like a Wood-Mizer and it was green.
