Brake Squeak - Super 70 Question
Started by YellowHammer, June 02, 2019, 08:12:03 AM
YellowHammer
My Super 70 has a three lobed, rigid brake shoe that rides in the drive belt wheel, instead of the brake strap I had in my LT40 and I have no experience with this system.
I have noticed it beginning to chatter or squeak when I disengage the autoclutch and the brake engages.
I've tried adjusting it as per the manual, but still have the chatter and squeak upon blade disengage and braking.  Is this normal or something I can adjust out?
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
terrifictimbersllc
 Maybe this is where the missing chipmunks have gone. 😎
RichTired
YH,
   Time for another chicken...
:D
Wood-Mizer LT15GO, Kubota L2800, Husqvarna 268 & Stihl 241 C-M chainsaws, Logrite cant hook, Ford F-150 Fx4
Richard
Andries
YH:
What? You wanted a helpful answer?  :D  :D  :D
LT40G25
Ford 545D loader
Stihl chainsaws
YellowHammer
Sounds like chicken or chipmunk grease may be the answer.
YellowHammerisms:
Woodpecker52
Yellowhammer   The LT15 has a similar brake rubber lobes that fit down into the drive band wheel.  It will make noise when it first grabs, no big deal and no excessive wear that I can tell could spray a little belt conditioner on them or silicone spray if it bugs you.
Woodmizer LT-15, Ross Pony #1 planner, Ford 2600 tractor, Stihl chainsaws, Kubota rtv900 Kubota L3830F tractor
Percy
Quote from: YellowHammer on June 02, 2019, 08:12:03 AM
My 2003 LT 70 is no super but has the same brake on it. In almost 12,000 hours, Ive had to replace the "shoes" twice and am about to do it again.  Mine makes noise some times and then it goes away for a year or so, then starts squawking again. The brake on an LT40 is a superior design IMO but the clutch design on the 70 means we have this setup..
