8 Deg-vs 10deg blades ?
Started by bama20a, May 05, 2012, 08:02:52 AM
bama20a
Morning all: I ordered a box of blades the other day. told the lady I wanted 10deg., She ask me what I was cutting mostly green? When I told her yes,She said I would be better off with the 8deg.
I was thing the 10 deg was a more less cut all type blade,Although I know there is not a one blade for it all,But The 10deg is the most common. Was she right or just trying to get rid of some over stock blades? ,& she knew I didn't know jack ;D,So she would get rid of them.
How much diff- is the cutting between the 8-& 10 deg-? Mark........
It is better to ask forgiveness than permission
Bama,you'll probibly like the 8's better, or won't be able to tell the differance.If the slim chance you don't like them next sharpening they can go back to 10.Frank C.
hackberry jake
I think that has a lot to do with your hp and the hardness of your logs. I need to pay more attention to my sharpener. I just eyeball it and try to get it close to what a new band looks like, thay seem to cut fine.
Bibbyman
Didn't know Wood-Mizer was making an 8° blade? We've converted to 7° and realty like them for oak.
We've use a lot of 9° DoubleHard blades and liked them until the 7° came out.
Janet knows what she's talking about. Wood-Mizer makes up the blades right there in a factory behind the headquarters in Indy. I'm sure they can control their production to a point were overstock is not a motive to get you to select one blade over the other.
Sawing since '94
bama20a
Sorry if I mislead anyone,But this order was not from Woodmizer,
Bibbyman
Quote from: bama20a on May 05, 2012, 01:34:38 PM
My bad.  I just had a senior moment.  ::)
Sawing since '94
bama20a
Quote from: Bibbyman on May 05, 2012, 02:03:57 PM
[/quote
  :D :D,No problem. I have them on a daily bases,
