AC question
Started by Woodhauler, June 28, 2012, 08:16:05 PM
Woodhauler
Is it necessary to change the receiver if the system has been open? Had to change the compressor and a line.
2013 westernstar tri-axle with 2015 rotobec elite 80 loader!Sold 2000 westernstar tractor with stairs air ride trailer and a 1985 huskybrute 175 T/L loader!
snowstorm
snowstorm
you also need a vachum pump to clean the system. then start over and hope the compressor is ok. they do not likr air and moisture
smwwoody
New drier and pump it down before you try to run it
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
oldseabee
be sure to add oil to the compressor and rotate it by hand for 2 or 3 revolutions before starting up.
GRANITEstateMP
  Sometimes it's also necessary to add oil into the system when replacing the compressor.  It depends if you drained the oil out of the old compressor or not.  Your best bet would be to check manual.
Best of luck, stay cool.  Matt
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
2016 Polaris 450HO
2016 Polaris 570
SureTrac 12ft Dump Trailer
