Need Help....Can you Indentify?? Circle Saw Bit n Shank
Started by Cutting Edge, August 19, 2012, 10:47:39 PM
Cutting Edge
This is out of a 48" 28 tooth circle blade.  I can't find any ID markings.  As you can tell, its been exposed to the elements for quite a long time.
Looked at Simonds and it appears to be a 3 regular shank and regular bit...??
Need help to confirm what style, size, etc.  Thanks for the assistance!!
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
- Sharpening Services
- Portable/Custom Milling and Slabbing
- On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
Ron Wenrich
It looks to be of the number variety of shank.  I've never used them.  But, it is a regular type of shank.  Whoever you buy shanks and bits from could give you a better idea of what it is and whether the saw is worth anything.
Could possibly be an old Diston they were quite simular to a #3.I would find a sample numbered shank and try it if not quite big enough probibly a Diston.If its a Diston saw your up poo creek they haven't been made for many many years,bits or shanks. Frank C.
Meadows Miller
Gday
Im thinkin and Hoping you have a #3 bit and shank there the good thing is that the saw plate and the pockets for the shanks look to be in good nick Mate  ;)
Worst case is you have a nice saw to hang on the wall or make a sign outa if it is a Diston  !
Regards Chris
4TH Generation Timbergetter
sealark37
It does appear that the previous owner got the maximum use out of the bit.
Weekend_Sawyer
I have a blade in a little worse condition, it's hanging on the barn as a decoration.
Imagine, Me a Tree Farmer.
