Reclaimed Wood
Started by Ron Scott, August 02, 2012, 09:51:32 AM
redbeard
  The metal cleaning and handling of DF reclaim beams is time consuming. they are extremely heavy also, but when you can get VG Qrt sawn it is worth the effort. If your sawing for a customer I charge a higher rate plus blades even though you may not hit metal its still hard on them.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
