Oil in Planetary?
Started by nastcat, March 03, 2013, 11:54:31 AM
nastcat
I have a Frankenstien skidder and am trying to figure out what type of oil to use in the planetary hub..It has axles out of a Hough, but i think they are Rockwell axles.  What kind of lube do i use in the planetary hub?   ???
treefarmer87
1994 Ford L9000
2004 Tigercat 718
1998 Barko 225
1999 John Deere 748G
FEC 1550 slasher
CTR 314 Delimber
Sthil 461
Sthil 250
nastcat
Do I use the same in the differencial and how much is it going to take?
oldseabee
Same oil, the diff and planetaries are connected through the axle housing so the oil transfers back and forth from each.
saltydog
I use 140 gear oil.You better buy a 5 gal pail if its empty.
Proud to be a self employed logger.just me my Treefarmer forwader Ford f600 truck 2186 Jonsereds 385 and 390 husky and several 372s a couple 2171s one 2156  one stihl 066  Hudson bandmill Farquhar 56"cat powered mill.and five kids one wife.
nastcat
Thanks everybody, I don't know if the differental is empty but the planetary didn't have more than a 1/4 cup in it. Thinking I better check all the fluid levels.  I probably should drain the diff and other planetary and put all the same oil in all of the axle.
