poulan 2050 2.0cu locked up?
Started by drobertson, January 24, 2013, 10:56:21 AM
drobertson
I was cranking my lil saw yesterday and just before it fired it seemily locked up, cant' pull the cord, and ideas?
Mag Craft
Well I would pull the starter off of the saw and see if it moves freely.  Look at the flywheel and make sure nothing is stuck to the magnet.   Try turning the saw over by hand with the flywheel.   If none of that does it, then pull the muffler and look into the port and see if anything is bad.   Pull the spark plug and look down the hole with a flash light.   Report back.
Does sound like the starter rope and cogs. Hope that is all it is.
macpower
If it never started, did you flood it and get a hydraulic lock?
Purveyor of Stihl chain saws.
Thomas 6013 Band Mill, Kubota L3400DT, Fransgard V3004, 2 lazy horses and a red heeler
drobertson
This is what I first suspected, and hope this is the case, although I have never had this much difficulty starting the saw, I will work on it this week end and find out,  thanks
Al_Smith
Some of those little Poulans used a plastic starter pulley that could snarl up the starter rope in such a mess it acted like the thing swallowed a rock .
Cut4fun
Had a guy bring in one locked up the other day. Just starter rope tangled around the plastic pulley was all his was.
Good thing he brought it over though. He thought the idle screw was one of the recoil screws and it was just laying inside there undone.  smiley_dizzy
drobertson
Amazing post, I was in a hurry the other day, two other saws, so I just grabbed and sawed. The insight has been good from you guys!  So here is what it was,
    Thanks guys, this is a lil fellow, but kinda nice when in small stuff, lots of centimental value as well, bought it at a fund raiser for my now passed sister in law,    david
Al_Smith
Another point to make .That little screw you are suppossed to use to tie down the rope end  has a tendency to chew up the nylon rope .I remove them to file 13 and knot the rope end with a figure 8 knot ..
drobertson
Hey Al,, yea, I defintenly stretch the cord in the few pulls I did before I quit.  I think these saws are almost the throw away variety for sure, but not this one,  it really cuts good for what I need when I need it, if you know what I mean. thanks man,  have a good one.  david
