Going small with Lucas
Started by Seaman, February 13, 2013, 12:52:32 PM
Seaman
I need to split a load of 2x8s ( reclaimed) for a customer with the Lucas. I am thinking of cutting a 90 deg shelf into a log, then pinning the 2x8 on edge to cut it vertically. Hope that makes sense. Any ideas?
wish I could draw on here , but don't have a clue.
Thanks. Frank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
fishpharmer
I think I understand your goal.  Sounds like it will work.  You essentially want to split 2"x8"s into two-2"x4"s?  If you make the log shelf 12" wide, possibly you could fasten a 4"x4" down so there is a 4"x8" opening to hold two-2"x8"s.
That way you could split two at a time.  Fasten a wood board at the ends or at least end resisting vertical cut.
Clear as Mississippi mud?
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
If you made a support with a couple of 4x2 standing vertical from each your normal log bunks, 2" apart. Put a stop at the front end to butt the board against, to stop the mill dragging the board back with the saw. Just make a cut though it the first time.
I would only cut one at a time so you don't have to reset the saw position at all. Get it set right, drop board into place, cut it, repeat.
Gasawyer
Sounds like a good idea. I think that I would only do 1 at a time to start with. Won't know till you try though. Good luck!
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
terrifictimbersllc
If you're sawing another log, you could also groove out a slot in the pith of a half-sawn log and tap the 2x into that, would be a pretty stable setup.
dgdrls
Seaman,
let us know how you proceed and add some pics,  you could
be showing me some future work.
DGDrls
Seaman
Thanks fellas,
Thanks, need to make them into 1x8s. I think the above ideas will work. I just HATE having to tell a customer I can't do what they want done.
Frank
Woodmizer LT40HD
Semper Fi
fishpharmer
1"x8"s ? You need to find another friend with a bandsaw ;).
sigidi
Frank, sorry mate, but you won't get 1x8's out, best you will get is 7/8x8 and then I'd suggest doing it horizontally. but all the methods rely on the 8x2's being "flat" to begin with - and to be honest they won't be :(
Seaman
Sidigi, I thought the same so ask a few more questions.
Found out last night the customer wants to use the boards for interior paneling. 2x8s come from a barn his Grandpa built, and he really doesn't care about thickness, long as thy are uniform. I'm thinking split and plane one side. probly end up with 5/8th or so.
Metal detector will get a good workout!
Woodmizer LT40HD
Semper Fi
sigidi
Frank, I recently did somethign similar with a bunch of old railway sleepers 8x5's took two boards out of each and left a slither of waste at the end. So one board had one clean fresh sawn face and the old face, the other board had two fresh faces.
I levelled a 'deck' using the sawblade to make sure it was true with the horizontal on the mill, then placed (for want of a better word) a fence along the left side and far end of where I placed the sleepers (making an 'L' shape) this held the sleepers inplace and I slid the mill up 40mm.(you may want to go something like 7/8) From there I left the mill at this height and just did all the sleepers horizontally. the bonus of this was I could adjust the bites I did as the blade got more blunt. To begin with I could do say a 4" pass and get through nicely, then once I was gettign down to a 2" pass (this timber was old as the hills and full of grit/sand/rust) then I would sharpen. Only thing I did was wind the head horizontal all day, and did small bites to get through quick.
Seaman
I think I will set up to try both ways.
I just put Locust sleepers under the mill and spiked them to the ground with 3 ft rebar. Then flattened the tops with the saw run all the way down. Now I have a base that is on plane with the rails, so I can flip logs over after flattening the top side.
Woodmizer LT40HD
Semper Fi
sigidi
