Small Engine Fuel
Started by bendjoseph, December 18, 2012, 05:01:09 AM
sharkey
Man I like that fuel price that Holmen's FIL is getting!  Wondering how the diesel is priced?
The best thing you can do with ethanol gas is to tune the engine for your local blend.  Then when your done using the tool, drain it.  I know its not practical to drain something that is used often, but consider something like a pole saw that isnt used but once every other month, drain it when your finished using it.
Fuel becomes very acrid after it sits in the sunlight and especially when exposed to moisture in the form of condensation.  Mix it in small lots.
