maybe a silly question
Started by lineguy82, September 25, 2013, 08:48:37 PM
lineguy82
I was just watching Bibbyman's youtube channel, and was wondering what was hanging down at the end of the mill. They look like strings of metal tubing?
95 chevy 4x4
Husky 562xp
Hardy H5
22T Countyline Splitter
...and hopefully a sawmill when the wife finishes college
mikeb1079
i think you're probably referring to the dragback fingers?  after you cut a board or whatever when the mill returns to the fore position they drag it back for you.  then you send it down a roller table or put it on the stack.  i'd love to have those!
homebuilt 16hp mill
lineguy82
i wasn't sure. I saw his board drag back was bringing the boards back on the return. Is the board drag back secondary to those "fingers"?
95 chevy 4x4
Husky 562xp
Hardy H5
Bibbyman
Quote from: lineguy82 on September 25, 2013, 08:48:37 PM
If you watch the sawing 8x8 video, you will get to see them in use.  I think I mentioned them in the walk through video. They are a copy of the guides that Wood-Mizer put on the LT70 and industrial mills.
Sawing since '94
lineguy82
95 chevy 4x4
Husky 562xp
Hardy H5
