42 inch bar
Started by goose63, October 12, 2013, 03:45:12 PM
goose63
I have a 24 inch bar on my 2171 Jred and a 42 inch for it don't use the 42to much would it be ok to use the style chain or should I use skip chain? thank's guy's :snowball:
goose
thank you to all the vets
sawguy21
The 42" will fit but if you need that much bar the 2171 won't be nearly enough saw.
goose63
That old saw pulls the chain on that 42 with Oregon chisel on it :snowball:
goose
clww
Anything past 24", I always use a skip-tooth chain.
Many Stihl Saws-16"-60"
18-Wheeler Driver
rfm7fxfox
Curious to know, what are you cutting that you need a 42" bar?
Dolmar 7900, Ported Dolmar 7910, Ported Johnsered 2172, J-Red 2186, Ported Husky 385, Ported J-Red 2258,Tree Farmer C5D,Timberjack 460 D.A. Grapple, 2015 KMC 2500 Grapple Track Skidder and 2005 Peterbilt 379 Logtruck
goose63
Some big old cotton tree's and big elm tree's :snowball:
goose
rfm7fxfox
42" bar is too big for that poor 2171...
nmurph
As others have said, 42" is WAAAY too much bar for a 71cc saw. But if you must, it definitely should be skip chain.
Oliver1655
Agreed skip chain for > 24" bars.  However, to me the big concern with the 42" bar is whether the oiler is able to put out enough oil to keep it lubricated.  I have  25" bar on a 56cc saw. Do I try to cut with the full length of the bar at one time? Seldom.  I will cut in part of the way then move the power head so as I continue to cut, part of the bar is over the previously cut area.  If the OP uses the same method, I could see it working - as long as the bar is staying oiled.
John
Stihl S-08s (x2), Stihl S10 (x2), Jonsered CS2139T, Husqvarna 338XPT California, Poulan Microvibe XXV, Poulan WoodShark, Poulan Pro 42cc, McCulloch Mini-Mac 6 (x2), Van Ruder Hydraulic Tractor Chainsaw
goose63
Thank's guy's I don't use all the bar it is oiling good and I grease the tip every time I put gas in. will get skip chain for it :snowball:
goose
celliott
You can easily cut twice the usable length of the bar. I'd keep the 24" on it (or even a 20'') that saw will be alot happier with the shorter bar.
I recently dropped a big cedar (probably close to 40" where I notched it) had to bore in both sides, it worked just fine. That was a 372xp w\20" bar.
Now if you were cutting big trees in a production setting, a big bar is probably the ticket. But then so would a 395xp or a ms660, etc....
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
deerslayer
Quote from: goose63 on October 15, 2013, 07:45:28 AM
If you're not using all the bar, then why use that long of a bar? I think about a foot shorter is more appropriate to the saw. I am running an 18" on a 2172 but that's because that's what I have that fits the saw. A 42" is longer than what Stihl recommends for the MS660 so you're really pushing the edge of the envelope with that length on a 2171.
Too many chainsaws, not enough wood.
Stihl, Husky, Craftsman, Mac, Homelite, Poulan. Some live here, some just passing through.
