Hydraulic problem
Started by smwwoody, November 07, 2013, 07:14:47 PM
smwwoody
I have a problem on my feller buncher.  When I try to raise the head it moves super slow.  If you throttle it down and  right back up it will then raise at normal speed.  you can then raise and lower it as many times as you want without a problem.  then if you open or close the gathering arms or the accumulator arms the head will go back to raising super slow.  If you have a tree in it it will not raise at all.  throttle it down and back up it will work normal again.  I switched the pilot lines on the main valve body between the raise and tilt spools and no change in the problem so I think the pilot system is OK.
HELP
Woody
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
leot
change the filter first then check the oil pickup screen if you can
48 in manual mill 1880's
Kemper
Change hydrolic filters, also might want to change fuel filters also.
smwwoody
Just changed all filters yesterday. Put in new pilot and main hydraulic filters agian today
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
Southside
Woody - is there a priority valve that feeds that line?  I had one in a 540 that was worn internally and would physically stick so I would loose hydraulic function, work the throttle or even shut the machine off and it would work just fine.  Drove me nuts, I pulled the filters, sump screen, pulled the valve it self and according to the book the springs were OK.  Well, I was going to pull the pump when I decided to remove the valve insides - problem instantly solved.  Hope you get it fixed soon.
White Oak Meadows
SPIKER
Quote from: Southside logger on November 07, 2013, 09:09:16 PM
Woody - is there a priority valve that feeds that line?  I had one in a 540 that was worn internally and would physically stick so I would loose hydraulic function, work the throttle or even shut the machine off and it would work just fine.  ...   Well, I was going to pull the pump when I decided to remove the valve insides - problem instantly solved.  Hope you get it fixed soon.
Above quote sounds like this could be a reasonable solution, seen similar on our drilling equipment.
Not familiar with the machine nore do I have any hyd/elec schematics to look at but a couple items to look at.
  Check for a shuttle valve (similar to the priority valves) as well on a return or a cylinder check could also cause it.
   Other items to look at (Pump Type) may have high/low flow conditions that could be getting sticky.
  Last item to check is for a bit of gook.o-ring stuck in the pilot flow into the main spool that controls it.
Quick test to up/down reversing it does that change it ot does it only happen from a full down post (can't go lower) >?
good luck.
kiko
Woody, hard to tell from here but sounds like a sticking port relief . Swap the boom up and boom down port relief and see if changes. The port reliefs will be located in the spool section it self,  just above where the pilot lines hook up.
Morewood
hyd/elec schematics are a must to troubleshoot problems ! anything else is guessing and speculation !
Frank S.
2008 Cooks AC3651 perkins diesel , JD 310C w/forks and thumb , International 8000 Dump truck , 16 ton trailer , and all the accessories .
smwwoody
Frank
I know what you are saying, but those are rare as hens teeth for Franklin equipment
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
smwwoody
Kiko
That sonds like a good next step I am on my way to try that now I will let you know how it works out
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
smwwoody
it ran like a champ all day.  I dont know how to fix a problem that will not show itself when i need it to
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
Southside
Where are you cutting?  I will come up and run it for you, for sure the problem, along with some others, will show up. :D
White Oak Meadows
smwwoody
I am in Arvonia for a few more weeks.  Come give it a try
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
KJ4WXC
1270d
Does this have load sensing hydraulics?
