Curly willow
Started by Den-Den, January 10, 2014, 08:38:20 PM
Den-Den
This is a willow hollow form that I turned this week.  I normally don't like turning willow (it tends to be soft and fuzzy) but this wood was too pretty to pass up.  12 inches diameter by 4 inches tall (the tree was large but hollow and 4" was all I had to work with).
Brad_bb
samandothers
Wow!  That is amazing!
WmFritz
I never realized that Willow could looks so beautiful. Very nice piece!
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Willow? All I can think of is weeping willow? and black Salix nigra
justallan1
Very nice work. What would you use that "willow hollow form" for? It is very unique and beautiful wood.
Allan
mudhog
Nice work, beautiful. You just never know what's under that bark.  smiley happysmiley
Jimmy
Doing the right thing might not be easy,but it's always right.
Ask, Seek, Knock
Bill Gaiche
That is some really pretty wood. bg
Left Coast Chris
Very nice work Den.    Was the wood from the flare at the base of the tree (compression wood)?   Also, what tool did you use to hollow it out?   What finish did you use?    Exceptional results  :) :)
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Den-Den
thefarm: I believe this is Black Willow (Salix nigra)
justallen1: It is decorative only
Left Coast Chris:  This piece was part of the trunk (about 5 ft above ground), I don't know how much of the tree was curly but I hope to get another piece.  I used a curved tool (patterned after John Jordan's tools) mounted in a Sorby arm brace.  The finish is rattle can lacquer.
All; thanks for the compliments.
That is a terrific.  Black Willow is one of the most unique and prettiest woods that I have ever sawn.  It makes wonderful wall paneling and as you have shown, very nice turned pieces.   :)
You also try to fool people with it  :)
ND rancher
Really pretty! Hope I can do something like that some day as I just bought a lathe and starting to learn.
TimberKing B-20.  Have been bitten by the bug! Loving life !
jamesamd
All that is gold does not glitter,not all those that wander are lost.....
pasbuild
Outstanding wood and workmanship  8) what is the wall thickness?
If it can't be nailed or glued then screw it
21incher
Amazing job. It must be nerve-racking  to turn the inside. How do you dry a blank of wood like that to prevent cracking of the finished bowl?
Lud
A real nice turning of a real nice piece of wood.  I know hollow forms can be a challenge and have done some but generally they're not functional enough for my tastes.
Here's a vase I turned just before Christmas from maple, red or Norway I don't remember, from the base of the tree.  As a vase, it probably is too wide at the top so I turned a disc that fits maybe 2" down in the throat with a 2-3" hole that the stems can be put through to control splay.  I sized the inside so a narrow jar could fit to hold water.   It's not quite a foot tall and about 8" across.  And useful.
Dodgy Loner
That's awesome! I bet the fact that it is willow adds to the perceived thinness of the walls, since the wood is so light. It begs to be handled :)
