TJ 230 question
Started by KWood255, February 18, 2014, 09:37:12 AM
KWood255
Hello, I currently have a TJ 215C, and I am looking at replacing it with a 230. I cannot find a series letter on the machine. It has a 3-53, Herc winch, 4 speed manual. I think it has the Eaton planetaries. I am guessing it is in the early-mid 70's but I dont really know. Anybody have any suggestions as to which series it is? Any considerable pros/cons with this series?
Also, for some advice on its worth, tires are 60-70%, 3-53 was rebuilt a few hundred hours ago. Seems to run clean and no leaks on the engine. There are a couple fairly minor leaks on the machine. (Hoses etc). Basically it looks quite good for a 40 year old machine. What might she be worth?  It has not been used commercially for over 10 years. Thanks fellas.
Neilo
If it has eaton axles, it should be about 75-76 onwards. If winch is Herc not eaton written on it, probably makes it a D series.
Other things we can go off are the model number in the footwell, probably something like 230GSE and serial no. or photos.
There are a few threads already on 200 series pros and cons. You should be able to get some idea from them. I am sure there will be people here to help.
Neilo
bushmechanic
 So I'm just a little curious about your post and wondering what advantage would it be for you to go to a TJ 230? You'll end up with all the same components 353 Detriot Diesel, Hercules winch, four speed transmission and the Rockwell planetaries. I don't think that model was around when the Eaton's were used and I think all the 215's came with the 220 Ford in them and I have saw them with both types of Rockwell planetaries depending on age of machine. What size tires are on that machine 16.9-30's?
KWood255
Thanks for the info fellas. The problem is that I sold my 215, and before it left the yard I already had my regrets about the sale.
I found the 230 locally, for a reasonable price, I think.
My 215 had lighter drive train (same as a 205) than the 230, with less power. Although I never had a lack of power with the 215! If I could have backed out of the sale of the 215, I would have!
sandersen
Sounds like a heckuva buy.  IMHO, the TJ 230d is the best cable skidder ever built...pound for pound.  I have a 66 230C and love it, and I've owned a TJ 225d which runs a close second in my book.  But the 230 is just a tad more rugged.  You won't be sorry.
"Make every step count."
logman81
Ya I have a 230d and it is a nice rugged machine and one of the easiest to work on.
Precision Firewood & Logging
sandersen
David-L
All Timberjacks are tough. Always have been and always will be.
                            David l
