Drive wheel lube hose
Started by drobertson, June 22, 2014, 07:34:36 PM
drobertson
Got done with another job, change the atf on schedule, but today I found a split hose!  It's the original since 04'
real glad to find this one!  Posting for those who might over look the obvious, as I did,
Ohio_Bill
Mine was split or chewed   also .
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Dave Shepard
My hose is still good, I just changed mine a couple of months ago. I wish you didn't have to remove so many bolts and panels to check in there. Checking the drive belt also requires a panelectomy.
This must be on your LT40 ?
POSTON WIDEHEAD
5 bolts 7/16" head and one panel.....hose on left......LT40.  ;D
Peter Drouin
I just take the blade cover off and I can see it . ;D
A&P saw Mill LLC.
License NH softwood grader.
drobertson
Access to the hose is not the issue at all, it is very easy to see it, the issue is time and deterioration to the hose.
Got it replaced, and filled.  Long needle nose pliers are handy in this one.  ;D ;D ;D ;D ;D :D :D :D :D :D
just for Peter! :D :D :D :D everything is funny up north I suppose?
Peter Drouin
Quote from: drobertson on June 23, 2014, 04:52:19 PM
Not everything, Life can be hard in the north, so I make fun when I can. :D :D :D :D :D :D :D 8)
A&P saw Mill LLC.
drobertson
You make plenty of lumber, so, I reckon you can grin your way to the bank! ;D ;D anyone that saws that much deservers to laugh and enjoy the spoils, the way I see it,
