That's what WDH said.
Started by POSTON WIDEHEAD, August 28, 2014, 07:41:41 PM
YH,
Yes. looks to be minimal sapwood.
Mike, I am in charge of Strategic Planning  :D.
customsawyer
That is some of the finest cherry I have ever seen. Several of the logs are around 30" diameter. When I first saw them I had to do a double look to make sure I wasn't losing my mind.
www.thecustomsawyer.com
mikeb1079
homebuilt 16hp mill
OK, so you can get one of the small ones.  Which log would you like to have?   ;D
