Should have ordered the FAOs with my LT35
Started by DanMc, April 21, 2024, 02:17:05 PM
Stephen1
I used 2 of them on my trailer as drop down supports on the rear for when I load my bobcat. I also used 1 for the mill after the FAOR dropped down going or did not get put up...( dumb things) and it went missing on the return from a portable job.  I now have 5 FAOR and one manual one.
DanMc
Quote from: Stephen1 on June 18, 2024, 07:17:35 PMI used 2 of them on my trailer as drop down supports on the rear for when I load my bobcat. I also used 1 for the mill after the FAOR dropped down going or did not get put up...( dumb things) and it went missing on the return from a portable job.  I now have 5 FAOR and one manual one.
OH!!!!!  This is excellent!  Yes!  I have a landscaping trailer that needs some blocking when running a heavy machine up the ramp.  I can add one of these to each rear corner to block it up without hunting around for scraps to put under there.
LT35HDG25
JD 4600, JD2210, JD332 tractors.
28 acres of trees, Still have all 10 fingers.
Jesus is Lord.
