gearomatic model 9
Started by drlewis, October 19, 2014, 08:31:21 AM
drlewis
my model 9 on my c4 wants in engage when driving and in freespool  it will go in and out about 4 ins,pulls and brakes good thanks for any help
jocco
If it is "winding the cable in" when its pulled out to hooK a skid  YOU HAVE A SERIOUS ISSUE, safety wise. electricuted-smiley Most likely clutch bands, dirt, cylinder rods coming out etc. Same if it does it after brake is applied Please look at it as I have seen this happen before and the results were not good. yikes_smiley
You may check out but you will never leave
chester_tree _farmah
Agree. Pull the side cover. Mine did the same. I had to remove the drive chain to get it back to the dooryard. A piece of the band shoe had broken off and was jamming. The band's were toast. Most likely a simple thing as as jocco says.
254xp
C4B Can-Car Tree Farmer
Ford 1720 4wd loader hoe
treeslayer2003
Quote from: chester_tree _farmah on October 19, 2014, 09:14:27 AM
yup, been thru that several times. you need a new clutch band. if those sit around a while, rust will push the friction material off the steel band and jam inbetween the drum and lining. i had to cut one once to get it off it was jammed so bad.
drlewis
thanks for info took side cover off , lining is coming off about an in. and is dragging. called PB and H and are in stock and not a bad price with core.
tantoy
drlewis, Who is PB&H? I will be needing bands for my model 9 soon also. Thanks
1968 Garrett 20 Skidder
1991 Ford 1920 Tractor/Loader
2000 Takeuchi tb135 Excavator
Stihl 020, 041 Super, 084
Husqvarna 61, 181SE, 357XP
drlewis
 pb and h in antrim nh. 1 888 588 3005 nice people  cozy from this site  got me the number in the spring ,turns out there an hr from me , seem to always have parts you need
tantoy
Harolds had them in Stock when I needed mine. The 9 were pretty common.
254xp
