Hydraulic Tensioner
Started by jrokusek, June 09, 2005, 09:29:32 AM
0 Members and 16 Guests are viewing this topic.
From Paul's picture I would venture to say that his is glycerine filled.   :)
Ga Mtn Man
The TK2000 is notorious for destroying pressure gauges (glycerin filled).  When the blade breaks a pressure shock wave hammers the gauge, which can only handle a few of these events before failing.
Orifices are one type of snubber.  On pressure systems that have rapidly increasing or decreasing pressure spikes, orifices lessen the effects of these energy pulses by blocking the wave energy using restricted flow.  They are recommended in dynamic pressure applications with mild pressure spikes.  The snubber shown in the picture is a piston snubber designed to protect gauges from large pressure spikes.  The primary purpose of filling a pressure gauge with glycerin is to dampen the movement of the dial indicator in applications where vibration or pressure pulsation is an issue.
xlogger
Paul, where did you get the snubber from? Also did you put it on after your gauge went out and got a new gauge or used the old one? Ricky
You can use a small needle valve as a snubber , close it and just crack it open, you may have to adjust it several times to get it just right. Frank C.
Ga Mtn Man
Quote from: xlogger on January 23, 2015, 05:04:54 AM
I got it off of eBay, NOSHOK #1325, paid about $12 including shipping.  I installed it along with a new gauge after my second gauge failed.
4x4American
Wow.  Thanks for the good info.  I've only broken one blade so far.
Boy, back in my day..
Larry
Quote from: Ga Mtn Man on January 23, 2015, 08:32:44 AM
That cost is less than all the gauges TK sent me when the mill was in warranty. ???
4x4American
Did they warrant the gauge?  I think I'll rig me up a snubber thanks for the tip, GMM
