Harbor Freight Verses= China
Started by jmw642, February 22, 2015, 07:58:46 PM
jmw642
Have been useing the Harbor sharpener for circular blades. Does a decent job but would like to do a better job because I do it for a lot of freinds. Am looking at the sharpeners from China on E-bay. cost about $430. Has anyone tried these and are they woth the extra cost. Would like to sharpen as they were new not a notch below. probably done 300 on the Harbor sharpener and there is a lot of guess work. Thanks for any help
dgdrls
Welcome jmw642,
are you asking about sharpening full size sawmill blades 48" diameter and up  or handheld circle saw blades 7 1/4" diameter?
DGDrls
Welcome to the Forestry Forum.
Are you from China?
Some info in your bio will help, such as general location.
Welcome to the Forestry Forum, jmw642.
As mentioned, much more information about the "Harbor" sharpener as well as the one in question would help.  Providing information about yourself, your location, and your interest helps with question answering.
jmw642
Thanks guys what I`m looking at is a heavy duty 125mm circular saw grinder. of course its built in China. Need it for regular carbide 6 to 20 inch blades. Am from Montana and retired, its just for a hobby more or less. Just like to get the blades as sharp as possible. Have gone through two of the Harbor grinders no bearings just bushings.
NWP
The Harbor Freight stuff isn't made in China?
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
LeeB
If you managed to get any sharpenings from the horrible fright ones my hat is off to you. Never could get the one I have set up worth a DanG.
clww
Many Stihl Saws-16"-60"
18-Wheeler Driver
jmw642
that is true  the ones I am looking a on e-bay are made in china. they are a lot more heavy duty then the Harbor ones. Just for example the Harbor sharpeners are about 7lbs. and these others are 30 lbs. Am just wondering if anyone has tried these and if they liked them
WH_Conley
I used to would not buy HF stuff til the last few years the brand names quality went down hill to the point I figured if I was going to buy junk I might as well pay for junk.
I have the HF circle blade sharpener, sharpens to 16 inch i believe. Took me a couple of sacrificial blades to get it lined out because the manual that came with it was worse than worthless. I have had people tell me that my sharpened blades were better than they were new. All I sharpen are Carbide. Let me know LeeB, we will get on the phone and see if we can't skin that cat. I don't know if I am using mine right or not, the finished product works.
Bill
LeeB
I'll try to remember to call when I get home. No use calling from over here and too expensive to boot.
Just Me
If you are doing a lot of blades you may want to be aware of this and take necessary precautions. I know that the fellow that does my blades is very cautious on that account and has very effective dust collection at the machines.
http://sharpeners-report.com/2013/07/17/cobalt-tungsten-carbide-anticipated-to-cause-cancer/
