The mill has met it's match. Big pine wouldn't lift.
Started by Delawhere Jack, April 26, 2015, 06:55:02 PM
Delawhere Jack
I mill very little pine, but when I do, I find it a pleasure to handle since it is so much lighter than oak. Maybe that's why I underestimated the weight of this log. 41" across the wide dimension on the stump cut, 18' long. About 34" on the small end. The Ole LT40 couldn't lift it. Ended up cutting it to two 9 footers. First time I've found a log the mill couldn't lift.
The picture is not out of focus, my face is always kind of blurry..... ::)
Ga Mtn Man
It's probably just as well you couldn't lift it as you would likely not have been able to turn the darn thing anyway.  I've been there.
downsouth
That's a big un for sure!
I haven't cut one that big,yet.
Bruno of NH
The big ones are fun !
That will make some nice lumber .
Jim/Bruno
Dave Shepard
I cut one about that big on a manual LT40 once. It was rolled off a log deck onto the mill. It was a beast to turn. It took me 9 hours to saw. :D
Chuck White
Wow, I haven't seen that one before.
I've sawn 34" x 16' Hemlock and the loader loaded them with no issues.
My tired old LT40 has loaded logs that my brothers Deutz/Allis 50hp couldn't lift.
I don't know what the limitation is on the loader of an LT40.
Delawhere Jack
Quote from: Dave Shepard on April 26, 2015, 07:21:45 PM
Yeah, but was it as BUTT UGLY as this beast?  :D This thing fought me every step of the way. HUGE knots, more waves than I care to mention. I knocked an hour off the bill because I was so upset at the results. The client didn't seem too concerned, but I was not happy with my work.
We also milled poplar and maple with turned out really nice, so it was not all in vain.
Delawhere Jack
Quote from: Chuck White on April 26, 2015, 07:27:16 PM
I believe it's 4,400lbs for the lift arms. It may be a little less.
POSTON WIDEHEAD
Delawhere Jack
Quote from: POSTONLT40HD on April 26, 2015, 07:41:21 PM
I've never seen a Pine look like that.  ::)
I'm hoping I never see one like that again...
Dave Shepard
ncsawyer
That's definitely a big pine.  The biggest pines I have cut have been 18 ft and around 34 to 35 inches and very green.  I cut those on a manual LT40 and had to load them with a 416 Cat Backhoe.  The Backhoe would just barely lift them high enough to go on the mill so I don't know what they weighted.  We had to turn them by hand and I can assure you that it was no fun.  They guy had one left that had huge knots on it and I wouldn't let him put it on the mill.  I know that we probably couldn't turn it with those big knots and he wouldn't be satisfied with the wavy lumber out of such an ugly log.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
JustinW_NZ
Ive had a pine like that, it was already halved by a chainsaw mill but although the mill couldn't lift it the farmers tractor with the mill could!
What a pig that thing was.
Gear I run;
tmbrcruiser
Hello from the southern end of the First State. I recently had a Loblolly pine log 8' long and 46" in diameter quarter sawn. One of the loggers I work with logged the tree from Redden Forest and was going to leave the butt log in the woods because it would not fit through the metal detector at the mill. So I brought the log home and quartered it with a chainsaw, used a small wood-mizer to saw into lumber. My gallery has some pic of the log, guess I should add some pic of the lumber. Glad to know there is another member from the First State.
Once you get sap in your veins, you will always have sawdust in your pockets.
Everything has to have a limit somewhere, and it looks like you found yours.  Smaller is sometimes better.   ;D
Tom L
the toolbox on this site says the weight is over 4800lbs
dats a big one
woodmills1
big and ugly
I brought one home yesterday, 44 inches at 12 feet, just plain butt log ugly.  It will be in my log yard for my estate to deal with after I am gone. :D :D :D :D :D :D
Hale87
This walnut log gave my mill the squirts today.....
2002 LT40HD sawmill, WM single blade edger, 23hp Kubota tractor, 2011 Kawasaki Mule, 2002 Honda Foreman, 1983 Case 480D backhoe
barbender
fishfighter
I fought a pine long the other day and I swore off anything bigger then 30". With the bad Tstorms that pasted thru today, I now have 5 trees down in my yard. One of them is a old red oak well over 100 years old. Well over 5' across. And yes, full of nails and rail roads spikes. Used to deer hunt out of it when I was a kid.
crowhill
I have a 14" hemlock in my woodlot that has 1" pieces of water pipe driven into it that was used for pegs to climb up to a tree stand at about 16' up. Only about 3" of the pipe showing now. I probably should just drop it to rot so I don't end up one day putting it on the mill!
TimberKing B-20, Kubota M-4900 w/FEL with tooth bar, hyd thumb and forks, Farmi winch, 4 chain saws.
shakebone
  we cut some big stuff in half so the mill will load it . just remember to raise loader arms while turning it or it could be bad ! Not that I know this . ::)
Lt40 super desiel , LT 35 hyd , New Holland ls 180 , Case 75xt ,
So many logs so little time.
