ship lapping two 6x6 beams
Started by hemlock man, September 10, 2015, 03:47:13 PM
hemlock man
Hi Everyone, I'm in the beginning stages of building a 16'x20' sugar house. My plans call for (3) 20' skids to use as the foundation. Floor joists will go on top of the skids.  I am having a difficult time tracking down 20' 6x6 skids for the foundation. I was considering sistering up two 10 ft 6x6 with a half lapped joint. I was told the lap should be 4' in length and oriented so the seam is facing up. This building is going on 9 piers so I would have three of these skids with the lapped portion centered up on the middle piers.I was going to use (3) 1/2 inch carriage bolts to hold the joints together.
I'm new to this so I wanted some advice from others. what do you guys think?
thank you
Dave
Roger Nair
Even though I don't know the loads, 6 x 6 seems too light.  I would guess that you would need at least 6 x 8 as perimeter beams and 6 x 10 for center beam.  A simple bolster could be a better solution than a half lap scarf.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
hemlock man
Thanks Roger. Not sure on the loads either, but I want something that's going to last. Jeez, I figured if I bought a set of I wouldn't have to worry about this stuff...
Would ganging up 2x6's, four deep using 12' and 8' pieces be a better option?
Roger Nair
Sure can gang up two by lumber but 6 inch beams seem to light.  What is the weight of the evaporator plus sap and firewood?  A central beam will pick up most of the weight, even with a short 10 foot span, a ten inch beam seems more up to the task.  You need to develop the relevant facts.
Roger Nair
Better yet, why not put the evaporator floor on earth, crushed stone or a slab of concrete.
hemlock man
Its a small evaporator, I'd say 250 pounds. Firewood will be outside. The building site has a pitch to and getting acess with a concrete truck is not possible, so I went with piers. I'd like to store things like a gator and quad during off season. That's it for heavy stuff
hemlock man
TheRe are 9 piers all together. Pier square is 154 inches by 208 inches. floor joists will be 2x6 on end and will overhang the piers to get a 16x20 floor plan.
All rough cut full dimension
