94 450C
Started by timberjack 450, October 08, 2015, 07:54:26 PM
timberjack 450
I just bought 94 450C dual arch and when I rev it up the bottom right light comes on. And also the tranny pressure gauge comes up slow to the blue. It shifts and climbs with no hesitation, it's just when I am parked and put it in 1st that it takes a few seconds. I was wondering if anyone had some advice for me.
90 450 Timberjack, JD 650 G dozer, Hitachi 120 excavator, 2400 morbark chipper, 85 Western star log truck,and a 22-22 Blockbuster processor
Almost forgot, and a very patient woman
so il logger
Not sure on the light. When mine is first started it takes 3 seconds or so for the charge pressure to build, as long as the gauge is showing good on the pressure then mine has no lag when shifting to gear.
kiko
First thing to do is change the transmission filter.  Suction comes to pump ,exits pump , through filter, back to trans pump and into trans. Suction is internal.
ga jones
The bottom red light is the blocked filter light for the transmission.
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
timberjack 450
Thanks for the replies. I am going to change all the oils and filters. The bottom right light is yellow but it has to be the tranny filter light. And I would assume that's why the tranny pressure gauge fluctuates so much. Pretty sure Dextron 3 goes in the tranny. Thanks again for all the help. Now all I gotta do is find a used 24.5x32 tire. Pretty uncommon size.
ga jones
  maybe this will help. I see that size tire on Craigslist in the south east a lot
ga jones
Also there is a screen on the bottom of the transmission that should be cleansed.
ga jones
There are some hidden grease zircs on them also. Two on the output shaft housings on the transmission. And one inside the dash on the steering column. (You need to remove the dash to get to it.) once you find it drill a hole in the dash to get to it! The steering will seize up eventually if it isn't greased.
ga jones
  screen that should be cleaned
timberjack 450
Thanks for the pics, very helpful. Looks like it is the hydraulic filter light that is coming on.
