Wedging logs when too wide for clamps
Started by Downstream, January 30, 2016, 08:44:49 PM
Downstream
I just spent the day sawing a number of logs on my ez boardwalk jr.  I bought it about a month ago and had sawn a few logs but weather and few other things kept me away for a few weeks.  The mill continues to amaze me and cuts straight and smooth every time so far.  One thing i keep bumping into is that when I have wider log on the log clamps aren't able to be used because they interfere with side rail and saw head wheels.  I have heard people say they use wedges sometimes to hold the log in place when clamps don't fit but i cannot find any photos of this and not sure I understand how it works.  Does anyone have a photo of this set-up to help me out or other ideas to share?
EZ Boardwalk Jr,  Split Second Kinetic logsplitter, Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
kelLOGg
It really doesn't take much of a wedge to keep a heavy log from moving while sawing. I use several of these small oak ones as seen in the lower left. They are about 1.5 x 1.5 x 4 with one corner beveled. Can be made to any size.
PineNut
I use wedges also and some times on both sides of the log
Downstream
Thanks for the photo.  sometimes i need to see it vs read for it to sink in.  i will make a couple for todays milling and give them a try if needed.
Dave Shepard
I've used heavy wooden wedges for that before. Both to stabilize the log, and as a substitute for toeboards on a manual mill. They were oak 2" wide and about a foot long. Tapered from about 2" thick to zero. As long as the log doesn't move when you try to rock it, then it should be fine for the cut.
Kbeitz
It would be nice to have a way to just have the wedges on a crank so you could just crank
them in when needed... Or maybe even hydraulic.
Love machine shop work
and Wood work shop work
And now a saw mill work
I have also lowered the side supports some to allow a big log to shift to the left.
I always place something against the log to prevent it from rolling.  Extra insurance.
21incher
I made a couple of brackets that drop in the frame between the rails with long threaded rods that I tighten against the logs from the bottom to stabilize them.
I also have some angle brackets Hudson supplied with the mill that can be lag screwed into the ends of the log without interfering with the carriage.  :)
