I fixed my slow internet
Started by Sixacresand, September 08, 2016, 06:37:44 PM
jdonovan
hiltop3666 Your booster make/model would help too.
Sixacresand
Quote from: jdonovan on September 15, 2016, 12:21:11 PM
This is one I have from Amazon Prome.
weBoost Home 4G Cell Phone Signal Booster for Home and Office, up to 1500 sq ft
by weBoost
$353.28$
Hilltop366
Thanks for your reply jdonovan,
The cradle booster is a Wilson Sleek 3G +26dB Amplifier Kit - 460106
Link https://www.wilsonamplifiers.com/wilson-sleek-3g-26db-amplifier-kit-460106/
The House booster is a Phonetone 62dB 850MHz 3G GSM Cellular Phone Signal Repeater Booster Amplifier Yagi Antenna and Whip Antenna.
I did return the Phone tone so I no longer have it, On my way to the cottage I stopped by a friends house that gets poor cell reception an tried it there it seemed to work fine there.
Link https://www.amazon.ca/gp/product/B00SIUHG42/ref=od_aui_detailpages00?ie=UTF8&psc=1
jdonovan
get a signal strength app for your phone. The booster can't boost a signal if there is none to work with.
Once we know what band/strength signal you have then we can work up from there.
clearcut
Most Android phones report the numerical signal strength in
     Settings / General / About Phone / Network or Status
You can enter Field Test Mode on iOS by entering a code in the phone app
     *3001#12345#*
Call
This will give you a numerical signal strength.
Apps are also available.
Carbon sequestered upon request.
Hilltop366
Ok thanks again guys, I found a signal strength under settings / about device / status / signal strength.
At home it shows -85 dBm   14 asu
I'm going to try it at the cottage this weekend hopefully but I got an idea I will get very little to no signal on the ground.
I was wondering why the tower that is almost twice as far away (rogers) works with the booster better than the tower that is closer (virgin / bell) and they are almost in the same direction. The only thing I can think of is the rogers one being farther away would have the signal scattered farther apart compared to the closer one. Sort of a shot gun effect?
