blue stain yellow pine for board and batton
Started by Raym, August 08, 2018, 04:48:07 PM
Raym
Is there any reason not to use this for board and batton siding on my shop build? The walls are traditionally framed (stick framed with plywood sheathing and tyvek).
I have plenty sawn (only need to sterilize) and if so, I was going to resaw into 1/2" boards.
My other option is to use white oak but it is not sawn yet
Thanks in advance
'14-LT40 super, nyle l200m kiln, vintage case 480E loader.
It's not the fool that askith, it's the fool that agreeith.
Lawg Dawg
I'd use it, no problem...you could also sho-sugi-bon it
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
bags
The only reason not to use it would be if you don't like the color.lol. Blue stain is a fungus, and sets as soon as the board dries. The boards structure is the same as any other lumber.
firefighter ontheside
Use away.  It will probably all turn grey anyway.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
Dave Shepard
Blue stain means sapwood. Sapwood is not very durable exposed to the weather.
Quote from: Raym on August 08, 2018, 04:48:07 PMMy other option is to use white oak but it is not sawn yet
This would be my option.
Raym
Quote from: Magicman on August 09, 2018, 05:01:55 PM
I think this is the route I will take. Since its just siding, I don't see any reason to saw any more than 1/2" thick though. Or do I
ljmathias
I saw my live edge pine lap siding at 3/4" and don't plane. Planing would help a lot- better finish and less uptake of stain/sealant plus make the water run off better. With pine too thin, cupping is a problem for me but then I put mine up without drying- let nature do that for me.
Keep us posted on how the oak works- inquiring minds and all.
LJ
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
samandothers
I did not sterilize my pine board siding.  I coat the outside with an oil based protection from weather.
@Lawg Dawg did you burn both/ all 4 sides?
smcclure
I used blue stain boards as siding on my shop and just spray a little water sealer every few years.  Been up for about 9 years and still hard and not showing any signs or rot.  I also left mine 1" thick.
Scott
Beavertooth
If you saw your white oak 1/2" you will probably have a bunch of boards that will cup and split all to pieces. The first lumber I sawed up for a guy when I got my first mill in 2005 was a bunch of oak of several different species and he wanted it sawed 1/2" so I told him I would saw it however he wanted it since I did not know any better at the time. So that is what we sawed it and every bit of it split all to pieces when it dried. Good for nothing but a bond fire.  Live and learn.  :-\ :-\
2007 LT70 Remote Station 62hp cat.
Lawg Dawg
Quote from: samandothers on August 16, 2018, 11:02:50 AM
I burned 3 sides on purpose...but all that flame from the 500,000 btu torch head will scorch the back too
Pro Sawyer Network
Stephen1
