Kebitz should know how to do it...
Started by Ljohnsaw, February 19, 2018, 11:58:54 PM
Ljohnsaw
K,
I have an OLD 2hp B&S motor on a centrifugal water pump.  It has the old wind a rope pull on it.  The motor usually starts on the second or third pull so you have to re-wind up the starter pull each time.  Kind of annoying.
I also have a "newer" 2hp B&S engine (actually 4 now) from sidewalk edgers.  They all have the recoil pull starters.  I pulled one of those off hoping to put it on the pump motor.  Only the crank shaft extends into the recoil to support it.  My pump motor doesn't have that extra long crank shaft.  It's not worth "rebuilding" the motor to have the right crank to support the recoil and the edgers cases don't mate up with the water pump.
Have you ever done a swap for a recoil starter?
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Davis Little Monster backhoe
Case 16+4 Trencher
Kbeitz
I have taken the recoil off snowmobile engines to put on the old Briggs. You also need to take the cup thats on the flywheel. Your trying to use the ratchet. The ratchet in Snowmobiles is built into the rope part. The flywheel on a snowmobile only takes a cup. Kinds like some older chainsaws.
Love machine shop work
and Wood work shop work
And now a saw mill work
Ljohnsaw
Hmmm, ok.  Now that I think about it, there are some other makes of lawnmowers that have that other type of pull start.
Thanks for jogging my memory.
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
florida
I had a tough-to-start mower with the pull start that wore me out. I chucked a socket on my cordless, stuck it on the crankshaft nut and off it went. Never pulled that rope again.
General contractor and carpenter for 50 years.
Retired now!
Ljohnsaw
Quote from: florida on February 20, 2018, 11:07:37 AM
Yeah, but this motor is not tough at all to start.  Just that you have to pull the manual choke slider out (every time) before you start.  If cold, you have to gradually push it back as it warms up (30 seconds?).  If warm/hot, push it almost all the way in (keep out about 1/8") so you don't kill it (flooding).  If you go too slow, too fast or too far, it stalls.  The choke is old an worn so it doesn't slide too smooth.  And the kill switch is a toggle on the head that shorts out the spark plug wire.
Working up there, you generally are running the pump for 10 or 15 minutes when washing down or wetting down a work area.  When you go to start it, you forget to do one of the required things - flip the kill switch off, pull the choke, check the gas, etc and you end up having to rewind the pull rope a couple three times.  Just an inconvenience, not the end of the world.
There are dozens of free mowers on CL everyday.  I'll just have to look for that other type of pull start to scavenge for my pump.
Now the other 2hp motors I have, I plan to mate one to an old lawn tractor rear end so I can make a Kbeitz gas winch for my log arch.  I'm done messing with an electric one (and batteries).
John Sawicky
SkyTrak 9038
Ford 545D FEL
Genie S45
Case 16+4 Trencher
