Adding power feed to a LT28
Started by WLC, March 07, 2018, 03:28:45 PM
WLC
Has anyone here added power feed to an lt28 after the fact?  I'm afraid shoulder issues that have cropped up recently may move me away from turning the crank on the manual feed and get a power feed module to put on my mill.  How much trouble is it to retrofit one onto an existing manual feed mill?  Thanks for any help.
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
starmac
I have not done it, but I do not think it is too complicated. A young man bought a new one here a couple of years ago and added it either right off the bat or at least pretty quick, he talked like it was a painless upgrade.
Resonator
I have not added it yet to my LT28, but it looks like an easy upgrade. I have already ran my mill without the crank rope, just pushing it manually. This was on bitter cold days when the rope was too frozen to work properly. It also helped to have the hitch end a little lower, so gravity could help return the saw head.
Independent Gig Musician and Sawmill Man
Live music act of Sawing Project '23 & '24, and Pig Roast '19, '21, & '24
Featured in the soundtrack of the "Out of the Woods" YouTube video:
"Epic 30ft Long Monster Cypress and Oak Log! Freehand Sawing"
CX3
I would think with a good drill bit and a little common sense that would be simple.
John 3:16
You Better Believe It!
MartyParsons
Hello,
  Everything comes in the kit. Remove this hitch, install the chain bracket. Install the power feed assembly run the wire to the battery. Install the power feed chain and you are all set. Should take you about 1.5 hours. Maybe 2 hours if you read the instructions first.
Hope this helps.
Marty
