conditioning in a DH kiln
Started by Den Socling, January 18, 2005, 02:38:12 PM
Den Socling
We already had this discussion and it had some good info, if I remember correctly. It was mixed into another topic and I haven't been able to find it. Does anybody remember where it was? Seems that 'misters' are the current fad in conventional kilns and I wanted to review what we had.
ElectricAl
Den,
We have a mister for our Conventional Kiln. Use hot soft water to keep the tips from plugging.  The biggest problem with water mister is it takes a huge amount of additional heat to ramp the RH fast enough to do any good.
I think a DH kiln would need an additional heat source to keep the temp up during the conditioning step.
Also, the higher the kiln temp during the conditioning step the better it will work.  120 degrees is fairly low.
A steam generator if sized right would work better.
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
