Swing mill blades
Started by still at it, March 15, 2018, 12:00:33 PM
still at it
 Blades for a swingmill.
Hi folks.
I'm about to build my mill and would like your thoughts on the blades.
I have a 3phase 15hp motor 2800rpm.
I'm looking for a blade to cut 10" mostly.
I will be mainly cutting Douglas fir and occasionally European oak.
Thankhou
Kbeitz
E-bay has a large selection of blades...
Love machine shop work
and Wood work shop work
And now a saw mill work
TKehl
I wouldn't try to reinvent the wheel.  Get a blade from Lucas, Peterson, or Turbo that has that cut capacity and adapt it to your setup.
Might try Bailey's to start.
Model 10 blade
In the long run, you make your own luck – good, bad, or indifferent. Loretta Lynn
