Tracked self propelled winches
Started by Cruiser_79, May 11, 2019, 06:39:32 AM
teakwood
Quote from: Cruiser_79 on May 15, 2019, 01:55:34 AMThey can swivel and move up and down. In german they're called Ruckerolle, I don't know the English word but would be something like backroller.
they called Rückerolle and work flawlessly, they're standard in Europe. Rücke means skid/haul wood, so i would translate it to skidroller
Skeans1
Quote from: teakwood on May 17, 2019, 09:15:37 AM
If I had to guess why you don't see them here is the weight and force say a large Doug fir would put on a setup like this, we've stood a D7 up on the sprockets before trying to move a large butt log with the standard fair lead/arch.
Cruiser_79
I saw somewhere that they are called feed roller as well. Uniforest make them hydraulic driven to prevent unwinding and to help when walking your cable out.
https://uniforest.com/products/forestry_winches/forestry_winches_premium/series_h/166/95_hpro/
Making a 15 ton machine less than 2.30 metres wide is a challenge indeed...
Found this one on youtube, a Morooka tracked dumper with winch and blade.
Raupenschlepper Morooka mit Forstausrüstung und Seilwinde 10to - YouTube
An older MCS800 with canopy is about 2.30 metres wide and has a total weight 0f 10 tons (loaded). With a winch, a kind of lifting frame/clamp bunk to move more weight of the log on the chassis and some added extra weight it will be at most 12 tons I guess.
They're quite fast and much cheaper than a dozer or tracked caterpillar skidder.
Satamax
Quote from: Cruiser_79 on May 17, 2019, 12:30:12 PM
Thanks a lot guys.
Well, it doesn't seem to be a common name in German. The only result i get is from Adler.
Schwenkbar rückerolle
