Need help from the pros - fixing tenon gap
Started by Dan_Shade, November 05, 2018, 09:08:08 PM
Dan_Shade
I have a gap. About a 32nd wide.
Any way to neatly fill this?
Burn in stick?
lots of dull bands and chains
Dan_Shade
Don P
Move the mortises closer to the inside corner of post to beam and shim the outside end of them, got any matching veneer scraps? The most seen side, the face you are showing is correct, you've shortened the hypotenuse correctly. Bearing is snugged up with something to wedge between the bearing end of the tenon and the end of the mortise
Dan_Shade
Don_Papenburg
If that is the top what is at the bottom ?  could you raise the  post ?  split the diff. The vast majority will not notice 1/64th .  And of those that do ,most of them will not mention it .
PA_Walnut
Any reason you can't just create another piece to replace?
Epoxy in lieu of wood glue is a prudent option as it will fill gaps, whereas wood glue will not.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
